Chat with us, powered by LiveChat
Written by Newton Cunningham at Cireson.
There are 3 interesting concepts that need some discussion in regards to the Application Model in Configuration Manager 2012, and they are the following:
In no way are these three items necessities when setting up the application model, but they are new and old items that need to be discussed. The following are explanation, points of view and troubleshooting local client log tips.
Maintenance Windows are very necessary and most might remember them being a part of the collections section. They still very much are a part of Collections, but there is something to take into consideration. Maximum allowed run time is really only important when maintenance windows are in place; if maximum allowed run time is longer than the maintenance window then the deployment will fail out. Verification can be done through checking the CITaskMgr.log. If the following is present within the log then act accordingly:
Distribute On Demand is a new and very good feature that can be useful for keeping large content off of Distribution Points (DP), yet clients can still receive the content. The “Allow fallback source location for content” check box must not be checked (both on the DP and the Distribution Type), and the client must be part of a boundary. The deployment must be made available to the client. In the Software Center, the end-user must trigger the application once, but it will fail. Even though the install failed, the DP now knows it needs this content and begins downloading the content to the DP. The end-user can click Retry and it should begin installation (may need to do a few times according to source size). The Appenforce.log will describe the sequence of events of the application install such as the following:
A Roaming Client is definitely new, but is still worth reviewing. The purpose of roaming clients is for the client to be able to go from Site to Site/ Boundary to Boundary and still be able to communicate with Configuration Manager and receive content. The ContentTransferManager.log gives info on retrieval and download of content from which DP the client is using; this can be very handy with troubleshooting. The following scenarios are great examples of what a roaming client is:
This should help explain different aspects of the application model. If you have any questions in regards to this then send me a message on my Twitter (https://twitter.com/JNewtonC) and follow https://twitter.com/teamcireson. Hope this helps everyone out there and makes life a little easier for you.
