The Cireson Portal for Configuration Manager
Productivity-Boosting Features and Benefits
iPad
Dashboard view
View a summary of information for your environment to proactively identify trends or problems, including client activity, client health, and client patch status.
Try It Now
Inventory data visibility
The inventory summary tab provides a quick and concise view of high-value inventory data, including:
  • Hardware
  • Software
  • Network
  • Client information
  • Applied updates
Try It Now
iPad
iPad
User device affinity management
View and manage user to device relationships within the Portal, enabling support teams to quickly determine which computer to troubleshoot:
  • View existing user to device relationships and associate new users to existing devices
  • Remove users from existing devices
  • Add new devices to existing users
  • Remove devices from existing users
Try It Now
iPad
Computer cloning
and cleaning
Easily clone computers to automatically replicate software deployments from a source to a destination computer. Remove targeted deployments from a computer using the Clean feature.
Try It Now
iPad
Software & deployment
templates
Reduce human error and standardize software and OS deployments, as well as objects, with pre-defined templates for consistency and increased efficiency. Define all the desired settings for your software creation and deployment requirements, including settings, schedules, user experience, and alerts.
Try It Now
iPad
Collection targeted
deployments
Quickly and efficiently target software to existing collections, or let us create collections on demand for your software, and retain those collections for future use.
Try It Now
iPad
Software, OS and MDT
Create and deploy packages, applications, task sequences, and operating system images (including use of MDT roles).
  • End users can begin to get updates in minutes
  • Easier access and less manual configuration to target software to end users
  • Customize the deployment of operating system images to new computers by integration with MDT attributes
Try It Now
OSD front-end
Windows Pre-Execution Environment (WinPE) application that allows quick and easy computer provisioning through integration with Configuration Manager Portal templates and settings during the provisioning process.
Try It Now
iPad
iPad
Deployment monitoring
View the status of all your deployments in a single tab. Drill into the status of a deployment, software, collection, and more.
Try It Now
iPad
External tools
Add built-in tools such as Remote Manage, Ping, or Remote Desktop to your Portal to access remote clients, trigger remote automation, and pass data to other websites through a new browser tab.
Try It Now
iPad
Report viewer
View reports that are important to your organization and job responsibility without having to leave the Portal to sort through hundreds of reports in the Configuration Manager Console. Set permissions so only approved individuals or groups have access to certain reports.
Try It Now
iPad
Role-based administration
Control who has access to use the Portal and what features and actions they can perform, without having to add the users into Configuration Manager. Control targeted groups and govern the size of deployments for non-administrators, to include notifications for awareness.
Try It Now
